How to import newer Anime Studio files into older versions
jessica951
Post by jessica951 »
Hi. I have a file i made in AS7 but i need to import it into AS6 but it says that I can't because was made with a newer version. What can I do?
Rudiger
Post by Rudiger »
Unfortunately, there is no native way to export an AS6 compatible file from AS7, which is really annoying.
Super8mm posted an AS7 to AS6 file converter implemented in Flash over at the VIP section of the Animator Forums. The only thing is you need to have at least 50 posts to access that section of the forum. Super8mm is also active on this forum, so you could try sending him a PM if you need the script urgently.
I also believe that Heyvern is working on a converter as a menu script for AS7, but not sure how far he has gotten with it.
jessica951
thank you ill try to contact them then.
