automatically changing order of layers
Rob Broek
Post by Rob Broek »
It happens during making a animation that de order of succession changes all by itself! Can I prevent that?
jessica951
Re: automatically changing order of layers
Post by jessica951 »
you can disable animated layer order
Rob Broek
Post by Rob Broek »
How can I do that?
jessica951
If you have your layers in a group or bone layer, click on properties, go on the Depth Sort tab, Uncheck "Enable animated layer order".
If you just have seperate layers, go on properties and on top uncheck "Allow animated layer effect"
Hope this helps!
Rob Broek
Post by Rob Broek »
Thank you. I am going to try that!
jessica951
Hope that helps. Tell me how it goes.
Rob Broek
Post by Rob Broek »
I have within ""depth sort" only the options "sort layers by depth" and "sort by true distance". I anabled the first and it worked!
jessica951
Rob Broek wrote:I have within ""depth sort" only the options "sort layers by depth" and "sort by true distance". I anabled the first and it worked!
Glad it worked! Check out my blog :D
