I figured the easiest way to handle her hands for now would be to make a switch layer (R. Hand) so I could just alternate between gestures, but I noticed a problem when that hand would go over part of the F. Hair layer and how it'd get hidden behind it. I was thinking it'd be a simple matter of using a patch layer and targeting the R. Hand, but I'm unable to target it because it's a switch. I've noted the same issue when trying to target something in a seperate group nestled inside the main bone layer I currently have everything in.
I worked around it by editing the hair line out of the F. Hair layer, going further down the layer order and editing it into the R. Hair layer so that I got the following result that I wanted.
I just wanted to know if there's a reason that patch layers can't target switches and groups. I don't understand most of the technical parts of how all this works, so any kind of insight would be appreciated. Outside of the tutorials, I'm just trying out things via trial and error. Just wondering about why patches can't be used like that, and I was also curious if anyone else had any recommendations on different options I could try for stuff like this in the future.
