Lychee wrote:Hello guys and girls
Thanks Sang820 for sharing, you and your team are my heroes.![]()
But... i'm a PC user, how to install this on a Windows machine ?
Edit: For PC users who use AS11/ 10 (perhaps it's not same for the olders versions), install to:
Windows/ Programs (64x or 86x)/ Smith Micro/ Anime Studio/ Resources/ Support/ Scripts/ Tool/---> df files
Windows/ Programs (64x or 86x)/ Smith Micro/ Anime Studio/ Resources/---> thisapp_pro_splash.ZH_CN.png
Best regards.
DRAGON MATRIX v1.0-----Sharing!
Re: DRAGON MATRIX v1.0-----Sharing!
Lychee wrote:It will be very helpfull because i dont understand how it work.sang820 wrote:Sorry, I will shortly make instructional videos --- please wait
As you can see above I tried some constructions around my modification of dueyftw and dkwroot method which gives very good results, but it's still difficult to implement with all these bones.
I hope Dragon Matrix can afford to simplified everything.
I think the ideal animation mode of Anime studio.
Guardar "pista de vídeo"
Can someone explain how this plugin works and how to set it up to use for a character? Seems pretty cool and I want to use it but I don't know how to set it up to use on a character.
synthsin75 wrote:You can install these to your custom user tool folder, which works for both 32 and 64bit. I doubt the splash matters, since it's named as a replacement for the Chinese version of AS. I haven't verified, but the joystick tool looks like just a utility file, so it could probably be put in the utility folder.Lychee wrote:Hello guys and girls
Best regards.
Zekewolf wrote:Can someone explain how this plugin works and how to set it up to use for a character? Seems pretty cool and I want to use it but I don't know how to set it up to use on a character.
Yeah, I know it's just a vanity image. If you rename it "thisapp_pro_splash.EN.png" it will work for the English version.sang820 wrote:synthsin75 wrote:You can install these to your custom user tool folder, which works for both 32 and 64bit. I doubt the splash matters, since it's named as a replacement for the Chinese version of AS. I haven't verified, but the joystick tool looks like just a utility file, so it could probably be put in the utility folder.老兄,我只是换了张启动图,满足下虚荣心。任何人都知道这是Animestudio,而不是“Chinese version of AS”。
synthsin75 wrote:Yeah, I know it's just a vanity image. If you rename it "thisapp_pro_splash.EN.png" it will work for the English version.sang820 wrote:synthsin75 wrote:You can install these to your custom user tool folder, which works for both 32 and 64bit. I doubt the splash matters, since it's named as a replacement for the Chinese version of AS. I haven't verified, but the joystick tool looks like just a utility file, so it could probably be put in the utility folder.老兄,我只是换了张启动图,满足下虚荣心。任何人都知道这是Animestudio,而不是“Chinese version of AS”。
EHEBrandon
What does this plugin actually do and how do you use it? I've seen the videos but I'm confused about what it does and how to set it up.
From what I can tell from the video and images posted earlier, DM is a script that allows you to create a single multi-directional 'joystick' style control which can be used to blend between multiple Smart Bone actions, where normally you'd have to use multiple Smart Bones and animate them individually. I haven't tried DM myself yet but it looks pretty cool. Depending on your character, this system also looks a bit complicated to set up, which is why they're offering a service to set a rig up for you. (Sang820, did I get that right?)
Since we have a long weekend, I think I can make some time to play with it today.
Greenlaw wrote:From what I can tell from the video and images posted earlier, DM is a script that allows you to create a single multi-directional 'joystick' style control which can be used to blend between multiple Smart Bone actions, where normally you'd have to use multiple Smart Bones and animate them individually. I haven't tried DM myself yet but it looks pretty cool. Depending on your character, this system also looks a bit complicated to set up, which is why they're offering a service to set a rig up for you. (Sang820, did I get that right?)
You're welcome! I'm installing it right now.
gilcartunista10
Instalei mas não funciona...pode me ajudar?
grato
grato
gilcartunista10 wrote:Instalei mas não funciona...pode me ajudar?
grato
- onurbeiren
work version moho pro 12?
https://www.youtube.com/user/animadorporacaso
Creator of the first Group Brazilian Anime Studio(Moho Pro 12): https://www.facebook.com/groups/998442436875703/
