... change the seed for random generators?
mrc
Post by mrc »
Is there a way, maybe through a layer script, to change the seed for random generators like particle distribution, noisy channel etc.?
In my particular case I have set up a particle layer to randomly distribute characters along a street but I would like to try different distributions.
Help!
Marc
You don't agree with the post above? Click here.
www.tricklabor.com/en
Re: ... change the seed for random generators?
mrc
Post by mrc »
Thank you. I really have to look into and get started with scripting. Don't even know where to put those lines of code.
Marc
if you're interested in writing scripts - this will give you a start.. http://mohoscripting.com/index.php?show ... _structure
mrc wrote:Thank you. I really have to look into and get started with scripting. Don't even know where to put those lines of code.
Marc
Find "SetRandomSeed" in the particle layer tool, and change the values? Just a guess. I haven't tried it.
http://www.mediafire.com/file/saufux9il ... rticle.zip
this will do much the same as the "randomise" button on the standard particle layer tool except that it pre-generates a set of random numbers so you can step forwards and backwards through them; and it stores information with the particle layer so that the same set of numbers can be accessed across multiple activations of the tool / moho.
more in the "readme" in the zip.
hope that helps!
