How to "glue" two different layer together ?
AuzulVox
Post by AuzulVox »
I'm still new to moho, in live2d, there's a function to "glue" 2 different layer so it "stretch" whenever it moved apart from each other
This is the link to the video I have problem with
https://drive.google.com/file/d/1YUpSZs ... sp=sharing
I want to connect the pelvis and rib together, so even though they're seperated they are still "glued" together
Several thing I've tried after consulting the discord channel so far
  • 1
I tried to create a warp mesh at first, but it deform weirdly
https://drive.google.com/file/d/1EXFXG5 ... sp=sharing
  • 2
I tried to unbind the layer from the bone and using only the mesh warp. It didn't work and the deformation seems to restart the moment i move the timeline, and the layer also rotated by it's own even though it isn't bind to anything
https://drive.google.com/file/d/18wzA_W ... sp=sharing
  • 3
Same as number 2 but bind to the root. It fixed the rotating but same thing happened with the deformation.
https://drive.google.com/file/d/1TkroZh ... sp=sharing
I hope I can get some help from this forum, it's hard to find answer on google for specific moho problem like this..
Thank you
Re: How to "glue" two different layer together ?
I'm not sure, but the first option you tried should be working.
Is there any chance you could share the file?
AuzulVox
Post by AuzulVox »
Víctor Paredes wrote: Mon Jul 27, 2026 7:20 am I'm not sure, but the first option you tried should be working.
Can i share the files directly to you through dm or email ?
A DM is fine
