When I successfully import 3d-models and save this anme-file, the information of the Texture is alwasy lost if I close the File and reopen it, thought all Data-Files are shown in the Layers. First i thought especially my 3D_models do not work, but i also have this problem, when i use the 3D-Models, which are Library-Content of ASP. So when i reopen I see the white 3D-Modells, also the Animation, but i have always to reload each Model/texture again. So this is possible (and Time-costing), but Im sure this is not the way it was meant to be.
I've tryed to reproduce the error and I can't. I'm using AS for linux beta version. I've opoened a 3D animal that is provided with the program, save the anme file in other directory, close the anme file, ad reopen it again. No problem with the 3D object texture.
I think must be something missing...
Yes, I did. The problem is not, thats it never works. It just works before closing and reopening. If it was a problem of order, I think it wouldt have worked the first time. And as i mentioned also the 3D-Content in the ASP-Library do not work this way.
I found the problem. Its not just that u have to put mtl and obj-file in the same directory, as we already know. The solution is that u also have to put these 3d-Files in the same directory as the anme-file. I always had separate folders for 3d-content and anme-files. And excuse some bad english, im german. In the post above i meant folder instead of order
