How can I import BMP, JPEG etc + animate them?
MiKalEl
Post by MiKalEl »
Hi! How can I import BMP, JPEG, PSD etc images into Anime Studio and animate them with bones?
( I know that this is a very general question, but it's my first day :p)
Do the tutorials that come with AS...
MiKalEl
Post by MiKalEl »
I have done the basics..
Have you done the basics for bones? Image layers?
Read up on those in the tutorials and help and you should get the idea.
We love to help new users but I would like to see you at least make some effort on your own first. The basic answer to your question would just be a "copy/paste" from the help and tutorials.
MiKalEl
Post by MiKalEl »
i'll give it a try... :cry:
MiKalEl
Post by MiKalEl »
(..and yes i have done bones and layers :p)
I was just talking about taking a static image such as a BMP, import to it into the AS and then add bones on it.
I can't find the way of doing it right.
Not enough info. There is no way to know from that statement what trouble you are having. Read over the tutorials and help regarding bones and bone layers again.
Also try to be more specific with exactly what your trouble is. Post examples if possible.
Generic vague questions are very difficult to answer, "I can't find the way of doing it right." contains absolutely no helpful clues. ;)
myles
Post by myles »
Greetings!
If you only work with a single image, the best you'll get will be image warping, as in Tutorial 4.2 and Tutorial 4.3.
The best way to do it is to slice your image up into "puppet" pieces, patch up any problems at the joints/edges (if it's a photo use cloning, if it's artwork use painting tools), then animate them as in Tutorial 4.1.
A similar example tutorial for Flash can be seen here, except use the bone binding technique from Tutorial 4.1
Use .png files with transparent/masked background around non-rectangular pieces, or else you will have to create a vector mask in Anime Studio for .jpeg, .bmp.
I don't think you can import .psd directly
Regards, Myles.
-- Groucho Marx
fingertipsaint
Post by fingertipsaint »
Ok, I'm being a bit thick here..
I've imported an image from photoshop (a character).
The image has not been split into limbs yet, I want to get it working first.
I can get the bones moving fine but not with the image, the tutorial that covers this (the statue of liberty) has a vector layer that appears to be the link yet I can't find the tutorial that tells me about the way this layer works. Am I missing something really obvious?
Thanks
Domino
Please read carefully this help section and tell us if you still needing some help. If after reading you don't understand, please ask again and we'll help you.
NOTE: built in help also have same help section.
Good luck and welcome.
fingertipsaint
Yep, you're right. I had read it, I just hadn't read it 'properly'.
It's all good now, thanks.
