Layer To Bone
Rappybas
Layer To Bone
Post by Rappybas »
Hi,
I have a question.
How do I connect a layer to a bone?
I tried to put the layer in the bone 'map' in the right under corner.
but when I rotated or moved the bone, nothing happend :S
How can I do this?
Or is there any tutorial? :D
fiziwig
Post by fiziwig »
Select the vector layer you want to bind in the layer window. Cick on the Bind To Layer tool in the tool window. Click that tool on the bone you want to bind that layer to.
--gary
Rappybas
Post by Rappybas »
Thanks, It works.
But it only works when I press Z to 'manipulate' the layers.
Not when I just rotate the bones :S
fiziwig
Post by fiziwig »
Rotate Bones in frame 0 rotates the bones independent of anything they are bound to so you can reposition them relative to the vector layers.
To have Rotate Bones also move the bound layers, you must be in any frame other than frame 0.
--gary
Rappybas
Post by Rappybas »
Ok Thanks! :D
So frame 0 is actually the set-up frame, wich won't be viewed in the animation?
fiziwig
Post by fiziwig »
That is correct. Animation starts with frame 1.
--gary
