Video import crashes (AS6 Pro)
kavlor
Post by kavlor »
Ok if I import a small quicktime video and click fastbuffer everythings ok but if I import a HD quicktime and click Fastbuffer it immediately crashes and quits.
Also not sure how this happens as I cant seem to repeat it at the moment but if I reimport a Mov file(maybe HD only again) I get a 'Anime Studio 6 has encounted a problem and needs to close.We are sorry for the inconvenience' but I can still do stuff like save work so its not a major problem.
A lot of AVI codecs that used to be visible in AS5.6 are now invisible/blank when I import them but Mov files are visible.
Blue
Post by Blue »
You could be helpful to give them your computer info, and the codecs you were using.
joelstoryboards.com - (WinXP SP3, ASP 6.1)
kavlor
Post by kavlor »
Windows XP pro
AMD Athlon 64bit xdual core 6000+
4gb ram
Ati HD4800 series Graphic card
Codecs well Divx for a start but just about every one I throw at it,uncompressed is ok though.
Ok this is fixed with 6.1 as is the problem loading in certain other codecs like Divx and XVid,now they can be seen and are not blank.
