How to mix real life and cartoon....
CrAzY Dan
Post by CrAzY Dan »
How can i do this because when i import the file, it is all fuzzy and i can't see what i am doing or where i am placing my character. How do i do it?
Thanx!
CrAzY Dan :lol:
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
Hiddicop
Post by Hiddicop »
Hmm.. I havn't had any problems with this. Maybe you just have the "fast buffer"-option selected. That makes is look wierd. Turn it off in the "Display Settings"-window (on the bottom of the mainscreen).
If this isn't the problem, what format are you using on your video-file?
CrAzY Dan
Post by CrAzY Dan »
I'm using .avi . Is that the problem?
drdemoman
Post by drdemoman »
thats shouldn't be a problem. I've just been mixing some real life footage in moho and it works great. Does it show up properly when you render? Also whats the dimensions of your project and your video file?
CrAzY Dan
Post by CrAzY Dan »
The width is 320
The height is 240 and the frame rate is 24fps.
The file i am using is .avi.
Heres a screen of what it looks like when i put it into moho.
http://www.freewebs.com/z3planet/Real%20life%20prob.bmp
And when i render it, the movie is only a black background.
Hiddicop
Post by Hiddicop »
I sometimes have a problem with avi-files to. They get a wierd obacity, sometimes get inverted, and solorized (I think that's what it's called), colors. But it works to render, for me. So what I recommend is that you insert the avi-file, and then render (without "Extra smooth images") to Quicktime, and then import the result. It shouldn't take that much extra time.
Otherwise many videoediting-programs support QuickTime as an export, so you can also convert the AVI here.
But it should work with AVI. Maybe it's the codec that's wrong, or maybe the framerate (I'm not sure if it makes difference). Set your project settings so it has the same framerate as the AVI, and see if that helps.
Otherwise, I have no idea. Can anybody else figure out what's the problem?
CrAzY Dan
Post by CrAzY Dan »
Yes, thats what it does! SOLARISES!
But when i render or export, it is all black. What now?
nobudget
Post by nobudget »
.avi is not more than a container for video, it could be compressed with many codecs, and I assume your file is encoded with a codec that does not work well on your system. I always use avi in standard PAL DV compression at 720X576 pixels and that works fine, both in preview and render. Can you recompress the .avi in an editing package or Virtual Dub to see if that makes a difference? Or check which compression was used?
Good luck,
Reindert.
www.nobudgetvideo.com
CrAzY Dan
Post by CrAzY Dan »
i've done that and it works in preview and render, but i can't see it when i am working on the animation. Now what?
drdemoman
Post by drdemoman »
if you want to know which codec the video is in you can use the cool little prog called avicodec
http://avicodec.duby.info/
Well it still suggests that fast buffer is selected. Hmm does the video have an alpha channel?
CrAzY Dan
Post by CrAzY Dan »
fast buffer isn't selected and what is an alpha channel?
nobudget
Post by nobudget »
An alpha channel is transparency information in the picture/video. It tells the file whether certain parts are translucent when rendered. Very few if any .avi files have alpha information though. .png and .tga image files and some quicktime codecs use it. Great for partial overlays. Maybe something is wrong with the direct-x drivers or your quicktime installation (I'm not sure how Moho displays, I believe using quicktime).
Reindert.
CrAzY Dan
Post by CrAzY Dan »
Still have the problem.
nobudget
Post by nobudget »
That's ok, you're still young, you'll figure it out before you're old :twisted:
Can you put the avi somewhere online for me/other members to look at the file to see what's the problem?
Reindert.
CrAzY Dan
Post by CrAzY Dan »
nobudget wrote:That's ok, you're still young, you'll figure it out before you're old :twisted:
HAHA!!!! :wink:
Here is the one i am using for testing:
http://www.freewebs.com/z3planet/small%20clay.avi
I will make a new one for the real thing.
