Making the end of a line round?
Zerdo
Post by Zerdo »
Hello,
I wanted to ask you, how to make a round ending of a thick line. Instead of a rectangle ending, a round ending (a half circle).
Thank you, greetings Zerdo
Lost Marble
Post by Lost Marble »
There's no way to change the style of line endings in Moho, but you could draw a small circle lined up with the end of the line to fake the effect.
Toontoonz
Post by Toontoonz »
If one created a brush that was a round black ball wouldn´t that create a rounded end?
Toontoonz
Post by Toontoonz »
I made a round black circle, stuck it in the brush library of Moho then drew with it (see above).
The ends of the lines are round.
Is this what you wanted? :?:
Make sure that Preview mode is turned on for the display quality in Moho so you can see the final drawing style.
Lost Marble
Yes, that's right - a round brush can do the trick nicely.
nobudget
Post by nobudget »
LM, do you ever USE your own program? :wink: It's not the first time a user pointed out an option you didn't think of, that's what you get if you leave people with choices...
Reindert.
www.nobudgetvideo.com
jorgy
Post by jorgy »
I think LM is shocked by all the uses and abuses people have found for moho....
:shock:
Zerdo
Post by Zerdo »
Thanks a lot, Toontoonz and Lost Marble for the ideas and hints. But I think, that this method needs sometimes more time. Then a button like Line Width could help. Could this be a feature in the next versions? Just to "make a line round at the ending" button. I think, this feature could help a lot at different things.
Sorry for my bad English :cry:
