Hopefully this will make sense.
It appears the simple way to do a relexion is to duplicate the layer in question, invert it and then change the opacity. (if it isn't do tell).
However, if say a character is stood behind a solid object which is also reflected you can see the character in the reflection. How can you stop this. Sorry to be a pain but if this is to do with masking, can you please explain it as if I was an 8 year old.
Correction can you explain as if I was an 8 year old. No offence to the young uns.
Reflections?
I did what you did and had an inverted image with reduced opacity as the reflection. I solved the problem with an object behind another by making the opacity of the reflected object 100% from the frame that the object disappears behind the other object until it appears again at which point I put the opacity back to whatever I used for reflection (75% for example.). Otherwise you see a mix of the two objects because their opacity is only partial. See my Happy Holiday Scene as an example
http://www.gardenguy.keepandshare.com
Thanks Garden guy. I haven't been able to see your file but I understand what your saying from your example. The problem I was having was the character was behind a door. So different parts of the character and background would be seen as the door was opening. This would happen over several keyframes.
