OBJ's inport without textures
Posted: Mon Mar 31, 2008 4:32 pm
by Misterprickly
whenever I inport an obj the texture is stripped from it.
what image format do they use?
Posted: Mon Mar 31, 2008 4:42 pm
by Genete
Be sure that the uv map file is in the same filder than the obj file. Outputs from Wings seems to work fine with Anime Studio.
See this for more info:
http://www.lostmarble.com/moho/manual/index.html
Full read the built in help and deep do its tutorials is highly recommended.
Posted: Fri Apr 04, 2008 1:55 pm
by realsnake
i was havin the same problem but u need to make sure that the texture is in same dir as obj file and also the name of the texture must not contain any space if u already did then rename the texture file and replace the space with underscore and also dont change the export settings if ur a 3 max user, only use jpeg or maybe tga.
My problem solved that way...
