Funny Monkey
Posted: Mon Jun 23, 2008 3:18 pm
by Crazypotato
What about a monkey? oh... yeah. i just used that to get your attention im giving a charecter laser vision with a switch layer, but i dont know how to do it without input (i.e. audio, song, etc.)
oh yeah and if you do want to see a funny monkey, follow this link
http://harpervalley.files.wordpress.com ... e-bush.jpg
Posted: Tue Jul 22, 2008 5:50 pm
by MangaManTez
OK when you get to the point in your animation, where you need to use the switch layer do it like this.
select the switch layer in layers window.
next click on the switch tool in tool window.
now in the main window you can see Active child, it shoul be top left of main window. from the drop down list, pick the layer name you need.
Good Luck
Posted: Tue Jul 22, 2008 6:46 pm
by MangaManTez
MangaManTez wrote:OK when you get to the point in your animation, where you need to use the switch layer do it like this.
Good Luck
or make a data file use note pad
here is an example, MohoSwitch1. is what you start with, then in the next line add the frame number (I have put 1 so my animation starts with the eyes open)
then you put the name of the layer you want to use(my switch layer name is OPEN)
in the next line i have ( 6 close ) so when my animation gets to frame 6 the switch will dsiplay the layer named close.
when you get to the end of the file you put ( MohoSwitch0 ) to end the data.
MohoSwitch1
1 open
6 close
12 open
30 close
MohoSwitch0
Remember when saving the file to do it like this
first change the ( Save as type ) to All Files.
Now name the file (I named my one EYES) and add its extention .dat
eyes.dat
Now click save
all done
