"clear animation from layer" destroys vector curve
Posted: Fri Aug 15, 2008 3:48 am
Here's another one. I don't get this all the time, but sometimes, when I do the "clear animation from layer" command on a vector layer, points where I adjusted the curvature with the curvature tool become pointy. It's very odd. Let's say I draw a hand, and smooth the fingertips by adjusting the curvature of those points. If I then remove the animation from that layer, it will completely sharpen all those points where I made the adjustment. I don't get this. . .if it's smoothed on frame 0, that doesn't count as "animation", does it? Frame 0 is the setup frame, and 1-infinity are animation frames, no? So if something looks a certain way on frame 0, isn't it more or less "permanent"? Why should clearing animation change it?
While we're at it, another thing that isn't always consistent is copying a change in line width or point curvature from any given frame back to frame 0. Someone a long time ago told me about the technique of making adjustments on a frame after 0 (sometimes it's easier to see what you're doing on an animation frame), and copying those keyframes back to 0. I've used this mostly with success, but sometimes line width and curvature for some reason don't copy successfully, while other changes do. Say for instance I have a vector layer that I resize, change the shape of, and adjust the line width on on frame 1, then copy the "point motion" and "selected point motion" keyframes back to frame 0. While the size and shape changes will be reflected, the line width will stay the same. I don't understand the "rules" that govern these operations.
EDIT
Okay. . .I think I posted too soon. Seems like if you only copy/paste the point motion keyframe without the selected point motion key frame, you get curvature problems. Is it the same with the line width/curvature not copying over? STAY TUNED!
MORE EDIT
Yes. That was it. Okay, so we've all experienced some personal growth today. You should feel very proud of yourselves.
EDIT
MORE EDIT
