Page 1 of 2
flash
Posted: Sun Dec 21, 2008 6:11 pm
by kfried27
I am working on a webpage and uploaded a swf file from AS. After uploading, the image came thorugh well, but the action occurred once and then was static (gecko is waving, after intial wave, gecko is just sitting there). What can I do to make it loop back and keep waving.
Thanks
Posted: Sun Dec 21, 2008 7:17 pm
by DK
You need to import te swf into Flash and make it a looped swf.
Cheers
D.K
Posted: Sun Dec 21, 2008 9:40 pm
by chucky
Also in the render select extra swf frame that will make it loop, sometimes with a white frame though, |I forget how to stop that from happening. I think I have figured that out in the past.
Maybe we need a sticky for exporting swfs, there a lot of common questions on this topic.
here's an swf I made last night, breaking a lot of the export rules btw like variable line width and point animation( those limbs are made as single lines without fills).
Click here to :
WATCH POOTERMOUSE SWF
Posted: Sun Dec 21, 2008 10:52 pm
by DK
Nice one Chucky. That reminds me of a question I've been wanting to ask.
Is there a way of masking swf output do that it doesn't export objects that run outside the main screen?
Cheers
D.K
Posted: Sun Dec 21, 2008 11:13 pm
by chucky
I see , I hadn't noticed pootermouse's cable extending past the scene there, whoops
Yeah that's a curly old one too.
If you need a quick and dirty mask , just make a frame shape larger than the off screen shapes on a new layer, I normally make this white or black.
This frame will show but at least it cuts out those unwanted off screen items, cleanly.
Otherwise you'll have to take into flash, I use swishmax as a cheap ( and belligerent) alternative for this process.
I hope the swf export gets better and better for ASPRO- it is a worthy feature.
Posted: Sun Dec 21, 2008 11:16 pm
by DK
This is interesting.
I just uploaded a webpage with an swf file embedded. I exported the swf raw without adding the extra frame and it is looping in my browser. Can anyone else see it looping?
http://www.wienertoonz.com/swf/index.html
If that's the case, you dont need Flash to make it loop but there could be a setting in kfried27's browser or in Flash player that needs to be checked to make raw AS swf's loop.
Cheers
D.K
Posted: Sun Dec 21, 2008 11:24 pm
by DK
Hi Chucky.
I wish that would work but AS masking won't export to swf's
Maybe in the next version.
D.K
Posted: Sun Dec 21, 2008 11:27 pm
by chucky
It works fine in firefox too.
I've re-rendered the mouse with no extra frame.
But it doesn't seem to loop.
The mystery deepens.........
Click here to :
BTW that's extra frame in project setting not render box.
Cool toon too DK
Posted: Sun Dec 21, 2008 11:33 pm
by chucky
yeah its not actually a mask but a shape on a layer, A rectangle with a hole in it.
It does render but as I said quick and dirty makes a frame around the anim with the colour of your choice, just to hide any dodgy extras hanging out in the wind.
Posted: Sun Dec 21, 2008 11:34 pm
by DK
Hey Chucky....that works fine
Just noticed, there IS a setting in Flash Player that you need to check to make swf's loop. Open a swf file then select the Control menu. You will see a Loop setting ther. Check it and see if your swf file online starts looping for you.
D.K
Posted: Sun Dec 21, 2008 11:35 pm
by DK
Ahh....a shape mask. Never actually thought of doing that!! Thanks Chucky
Cheers
D.K
Posted: Sun Dec 21, 2008 11:38 pm
by chucky
Hmmmm, already set to loop, makes no difference without that extra frame
Posted: Sun Dec 21, 2008 11:39 pm
by DK
It has to be a setting in the browser somewhere that is not looping those animations....I can't think where it would be though.
D.K
Posted: Sun Dec 21, 2008 11:41 pm
by chucky
It must be after editing in flash or swish to make the clean no white frame loop.... must be.
EDIT, nope , I found an old swf I did that never went to flash, looping cleanly.
WEIRD.
I think it may have had to do with where the loop start and ends, odd or even frames, something buggy and strange like that, I wish I'd written it down cos I'm opening old files and can't get the same result.
Posted: Sun Dec 21, 2008 11:48 pm
by DK
Ok...Googled the original prob:
Right clcik on the flash animation in your browser. Make sure your Flash Player settings for your browser is set to loop.
If that does'nt work download the latest version of Flash Player. That's all the info I could find outside of having to code it to loop in Flash itself.
D.K
[/url]
