rotate forearm from inside to outside in front of arm
Posted: Mon Jan 19, 2009 10:01 am
by hany rabi3
hi all. i tried this and i found it nice i need your opinion views
i drew arm and forarm in tow separated layers and then rig by 2 bone
but i did few points control
Posted: Mon Jan 19, 2009 1:54 pm
Was there supposed to be a link there for us to check out?
Posted: Mon Jan 19, 2009 2:39 pm
by hany rabi3
synthsin75 wrote:Was there supposed to be a link there for us to check out?
i am really dont know how to share my sample
Posted: Mon Jan 19, 2009 2:43 pm
by hany rabi3
i try now to share it
Posted: Mon Jan 19, 2009 2:46 pm
by hany rabi3
Posted: Mon Jan 19, 2009 3:28 pm
by mkelley
Vern does this technique all the time -- for "my opinion" I think it's okay but something I really don't find all that useful (I work in 3/4 and moving the downstage arm I simply rotate around down and back up and as quick as it comes it's not noticeable. For upstage arm I dupe layers and move forearm forward, which is a similar technique to this, but since it results in the forearm passing in front of the body I don't need to be very precise about it).
I'm pretty sure Vern's technique for this is well documented here (you could do a search if you want). It's even possible it was that technique that you found elsewhere.
Posted: Mon Jan 19, 2009 3:36 pm
by hany rabi3
thanks for reply and it is enough for me to find agreement or ok
so that,
i will continue with this till i learn another
could you refer me directly to what vern do,if possible
thanks alot again
