When I publish a movie to Microsoft Movie, it doesn't work!
Posted: Fri Mar 06, 2009 6:54 am
by ngh903
I've made an animation with a light blue background. I've uploaded it to Microsoft Movie and it played with a blue background. But when I published the Microsoft Movie, the animation had a black bacground. Has this happened to anyone else? And if so could you tell me how to fix it? Thanks!
Posted: Fri Mar 06, 2009 8:38 am
by InfoCentral
Sounds like a MS Movie problem as you say it played OK inside of MS Movie.
It works great in MS Movie
Posted: Fri Mar 06, 2009 12:06 pm
by ngh903
You're right. It works great when you assemble it in MS Movie. But when I publish it, the animation's background goes black. But everything else, like the subtitles, work fine.
Posted: Fri Mar 06, 2009 1:44 pm
Unless you put a background, like a colored rectangle, in your AS project it could be reading the transparency. The background color in the project settings is just sort of a fill-in for export that doesn't make use of the transparency.
Thanks!
Posted: Fri Mar 06, 2009 4:34 pm
by ngh903
Thanks you guys! It worked perfectly!
