Scatter Slowing - Not Bug?
Blue
Post by Blue »
I was using the Scatter Brush with a custom shape from the clip board. You can see a larger view of the shape in one of the images below, the "J" shape.
As I was using this brush the program would seem to freeze after a mouse up. Apparently there is some redrawing or re-calculation after a mouse up.
Zooming causes the same problem.
I noticed the above slowness with even a third of the number of J's in the scene.
I'm concerned because this doesn't look like a complex scene (to me at least). Here is the file:
http://www.joelcardinal.com/tmp/scatterSlow.zip
Pentium 4 2.8Ghz, 3GB RAM, WinXP hm SPK3, Intel onboard graphics, ASP6
Image[/url]
joelstoryboards.com - (WinXP SP3, ASP 6.1)
No, it's not complex, but look at the number of points in the 'J'!! Edit this so that there are a LOT fewer nodes, and you should be good to go...
