Offsets in Export Animation
Posted: Mon Nov 02, 2009 5:32 pm
by rmunoz
Everything looks fine in when I run the animation in Anime. But when I export thte video, two of the images are positioned differently on the animation. On each part (image) I set the origin so I could rotate the part around a fixed point. Does this cause an offset in the final exported animation??
Bob
Posted: Mon Nov 02, 2009 11:39 pm
by Mikdog
Hmm. That shouldn't be happening. Can you post a screenshot or perhaps a file? Is the offset by a large or small margin?
Try select another layer in the playback view and run the animation again. Still looks right?
Posted: Tue Nov 03, 2009 2:37 am
Do you export to SWF? In that case this happened to me as well.
Posted: Tue Nov 03, 2009 4:21 am
by rmunoz
This only happens when I export to swf. It does not happen when I export to avi or quick time. The offset is slight (maybe a distance relative to 5% of the screen) but significant enough to be a problem.
Looking to use the animation in a web based tutorial. Thought swf was standard. Do you know if avi or quicktime is just as compatible with most browsers?
I captured two screen shots showing the difference. How do I post an image from my hard drive?
Posted: Tue Nov 03, 2009 4:51 am
by Mikdog
You can post the image on
www.imageshack.us then paste the image address it gives you over here.
Yep...Anime Studio and SWF don't really work too well together from what I can tell unfortunately. You can export it to Quicktime and post it on a webpage. Far as I know most browsers will stream the video. Just be sure to use a good codec like H.264 or MP4 or something to keep the file size down.
Posted: Tue Nov 03, 2009 5:05 am
by rmunoz
Trying a few things to recreate the problem. Appears that changing a layer's origin does not export to swf. The image rotates around it's original origin (if that makes any sense). Looking for a work around but may just go with quicktime. many thanks.
Posted: Tue Nov 03, 2009 5:21 am
by rmunoz
OK last comment. The workaround is changing the parts origin before you import to Anime. I brought the original image (part) into photoshop and moved the part such that the desired rotation point was at the center of the workspace. Resaved the part file. When I import the part, the layer's origin is the rotation point. Looks like an Anime bug that can be fixed.
Posted: Tue Nov 03, 2009 5:45 am
I don't remember exactly, but I think I had put the image layer into a group layer to use the group layer's origin as the pivot point.
