640 x 480 vid
Posted: Tue Dec 15, 2009 5:30 am
by KartoonManagement
I made my vids this size now which has made it alot sharper but when i import it in wmm it lags behind the audio. I saved the vid from wmm and it came out find but its hard to edit when it lags. Does anyone know how to fix this.
Posted: Tue Dec 15, 2009 7:24 am
by Genete
Can you import it into other video player? Maybe your computer is not strong enough to play it? which codec are you using to create the video?
Try to export to image sequence and import it to your video editor as long as the audio. Export it from the video editor.
Posted: Fri Dec 18, 2009 12:33 pm
MY cpu is 3.3hz 2gigs of ram and a geforce 8700 graphics card.
Posted: Tue Dec 29, 2009 8:59 pm
by TheChewanater
I don't know if you've found a solution yet, but the cause of your problem is probably that your video is uncompressed. This makes it huge on disk and take a while to access. It also may be MPEG-2, which WMM apparently has trouble with.
It's kind of hard to tell what the problem is, though, since you didn't answer all of the questions you were asked. Can you tell us what compression or lack of compression you are using?
Posted: Wed Dec 30, 2009 8:08 pm
by meltedtoons
WMM sometimes does that, so export it form AS as a avi. then import it to WMM then export it with the 720p (or 1080p) setting and upload to YouTube and everything will be fine
Posted: Wed Dec 30, 2009 11:32 pm
by AmazingRobie
meltedtoons wrote:WMM sometimes does that, so export it form AS as a avi. then import it to WMM then export it with the 720p (or 1080p) setting and upload to YouTube and everything will be fine
How are you supposed to export from Anime Studio in .avi? I'm using version 6 and there's no option for that, only .mov or .swf or a variety of other image export settings, but those are the only two "video" settings available. Please let me know if you are using Pro or Debut, 6 or 5 or earlier...
Posted: Sat Jan 02, 2010 9:27 pm
by TheChewanater
Debut can export to AVI, I still have the box here in front of me and it says "Exports: SWF, MOV, AVI".
To find the problem, however, we need to know the codec or lack of codec. Switching it might help.
Posted: Tue Jan 05, 2010 12:21 pm
sorry for the late reply. It is uncompressed and is huge on the disk. Once i save it tho from WMM its fine and its good on youtube. It is just a hassle to edit when it lags.
I do export it as AVI tho. Oh and i did answer the questions...video editor: WMM and is my cpu strong enough. I guess the codec is on default cause i dont mess with that stuff.
