I'm exporting an image sequence that keeps getting two areas of black frames to show up.
Under my imported .avi layer I have a simple vector layer serving as a colored background.
I have an .avi element of a 3d model (made with ulead cool 3d). The avi shows the 3d element fly off screen and back on. However, i'm not moving the layer of the .avi--it was rendered that way in the 3D app.
Under 'image settings' i have the "has alpha" box checked. Is there a glitch here when the element flies off screen and all that's left in my imported .avi is an empty frame of, alpha? I'm lost.
When the element is on screen, all is fine.
When the element flies off screen, I get black frames.
BUT, if I export my .anme to quicktime for viewing it works just fine.
This only happens when exporting to an image sequence.
Exporting to Image Sequence has random "black" fra
I haven't unchecked alpha yet because it leaves the black background under my 3D animation from the other app.
29.97 fps on both.
My background is a gradient with grey and and a reddish-white, radial pattern.
The frames happen twice, both in the middle of the sequence.
Each of those times happens exactly when my 3d model flies out of frame. I am not "flying" it with layer keyframe btw. The imported animation simply has two parts where the model leaves the screen.
I'll experiment when I get back and try to post the .anme for a look-see.
Thanks again
29.97 fps on both.
Thanks again
- Víctor Paredes
no if you put the video inside a group and turn off the visibility of the group instead the videotouchdown wrote: if i kill the visibility though, the video starts over at the next point of visibility, correct?
