Weirdness with stereoscopic render
Posted: Mon May 17, 2010 11:55 am
by GCharb
Hello all!
Was doing some tests with the stereoscopic render and I am having a weird render with two 3d cubes.
If I render normally, this is what I get.
If I turn on stereoscopic rendering, I get this.
AS Pro 6.2
Anyone has an idea?
G
Posted: Mon May 17, 2010 3:25 pm
by swrecordings
it maybe the colors your using a different red/blue setting (.02 instead of .08 for example)
Posted: Tue May 18, 2010 1:14 am
by Rhoel
Agreed, this is an anaglyph problem - the reds and blues are blocking each other: If the blocks were grey, you would see the full cube shapes, with the cyan/red overlays.
Rhoel
Posted: Tue May 18, 2010 6:17 am
by GCharb
Hello again!
I turned the cubes to grey and it did solve the problem, did not anticipate that the colors would cause such results. I solved the black bg issue by adding a light grey plane in the back.
Thanks to both of you!
G
Animation
Posted: Wed Oct 06, 2010 7:03 am
by joby
There is a myth
ASP cant do fbf animation quickly
we can make soon fbf by switch layer mode by using a default dat file
i think
please coment
sorry for my poor english
joby
