Export camera data from AS for Lightwave?
Posted: Thu Jun 17, 2010 11:15 pm
by madrobot
Export camera data from AS for Lightwave?:
Is this doable? Is there a script for this?
(Or has Chucky lost his mind? If so, I shall set up a paypal button in my sig so we can all throw in to have him put down by the vet.)
Posted: Fri Jun 18, 2010 1:09 am
What type of data does LW need for import? I suppose it should be simple enough to export a text file with a list of key frames for camera movement data. The MAIN problem would be interpolation. The interpolations for keys in each program are most likely different and won't match precisely. The other option would be to output EVERY FRAME with a value. This would negate any interpolation issues but would create more complex data files.
Should be a "relatively" simple script... depending on what the import data needs to look like for LW or if it is in some kind of binary format and not plain text. If it isn't an ascii text format (like the AS format is plain text) it might not be possible.
Posted: Fri Jun 18, 2010 1:53 am
by Genete
I think that obtain a value for each frame is not so bad. Some hints here:
The MohoDoc has three variable members that retrieves the camera channels:
fCameraTrack (AnimVec3)
the camera tracking animation channel
fCameraZoom (AnimVal)
the camera zoom animation channel
fCameraRoll (AnimVal)
the camera roll animation channel
fCameraPanTilt (AnimVec2)
the camera pan/tilt animation channel
Then a simple loop can retrieve all the values of the camera for all the frames:
LM_Vector3 GetValue(int)
Return the value of this channel at a given frame.
Return value (LM_Vector3): value at the given frame
when (int): frame number
Same with the rest of camera channels if needed.
