Truncated Scripts
TheChewanater
Truncated Scripts
Post by TheChewanater »
I've been using AS Pro 6 on GNU/Linux for a while now, and it keeps throwing an error about end-of-file NULL characters where something else is expected in scripts. So, when I investigated, most of the menu scripts ended in this:
	moho.document:SetDi
or this:
	local radius = MOHO.
or this:
	l:AddChild(
Every script too big just ends after 2^12 (4096) bytes. And this has been like this since I first bought the product. Why don't I have complete scripts and where can I get them?
sbtamu
Post by sbtamu »
Have you upgraded to AS 6.2 yet? But, I do not know if there is a 6.2 for Pro, but its worth a try.
Sorry for bad animation
Those scripts are damaged or corrupted. The scripts are missing a bunch of stuff after the points you indicated. They aren't complete. You should reinstall AS or re-download any custom scripts you installed.
TheChewanater
They were like that when I got it, so I guess the Linux version of AS is broken.
I downloaded a trial of the Window$ version and got the scripts from it. They seem to work.
TheChewanater wrote:They were like that when I got it, so I guess the Linux version of AS is broken.
If that is true then all the linux users of AS would have noticed a problem. How did you "get it"? Was it a download from Smith Micro? A purchased CD? Often files can get truncated during a download. If it was "like that when you got it". Can you go back to the original source where you got it and try again?
TheChewanater
Well, I didn't edit them, and I immediately put them under the root user's control, so it's impossible to change them without the root password.
I could check, but it's a huge download and I don't care since it's fixed now.
