Frame interpolation is not only skipping frames while exporting (to MOV or PNG, either using regular or batch export), it is also not rendering timeline previews well.
The only solution I have found: frame by frame COMMAND+R then save as PNG: Big time pain in the @$$.
Destroyed my scene. Downgrading back to ASP 6.
Using: ASP 7 @ Snow Leopard 10.6.4
ASP 7: Frame Interpolation using Switch Layers: NOT working
Re: ASP 7: Frame Interpolation using Switch Layers: NOT work
I'm sure SM is aware of this and they will fix it on 7.1, I hope. I hope, at least, SM will post something about when it will be patched though.Erick wrote:Frame interpolation is not only skipping frames while exporting (to MOV or PNG, either using regular or batch export), it is also not rendering timeline previews well.
theunrestedone
Anime Studio Pro 7 full of bugs all over..
I have found problems with both interpolation in switch layers and brush's rendering out animated when they were not supposed to. both these problems did not exist on previous versions of amine studio and are very frustrating.
I am in serious doubt it was a download problem or anything i am doing. Is there no fix for these problems i see them complained about but can not find any suggestions on how to change or fix the issue.
theunrestedone
There is a updated exe available on these forums for the switch bug, and it works perfectly as far as I can tell.
viewtopic.php?t=17219
