Creating Pixel art in Anime Studio Pro 7
Posted: Sat Dec 04, 2010 11:31 pm
by Vercingetorix
Hi
Is it possible to export a vector animation in AS pro 7 in such a way that it has a line width of only 1 pixel? like how lines are displayed when working in wireframe mode.I have tried exporting using the smallest line width possible but the result is very ugly & contains broken lines & unintented width variation.
Any help would be appreciated
Thanks
Posted: Sun Dec 05, 2010 2:46 am
by Mikdog
I don't think so, unless you create a grid of squares, make vector animation, export larger and then resize without antialiasing in another program.
I wrote a similar thread about this probably around a year ago, you could probably search for it, some good suggestions there
Posted: Sun Dec 05, 2010 4:34 am
Smaller line widths are tricky to render. I suggest you build your scenes in a way everything looks good, then change the project settings to some ridiculous oversize, like 4000 px wide, export as PNG sequence, and batch- reduce those images in Photoshop. The resulting line will be much smoother than what AS renders.
Posted: Sun Dec 05, 2010 7:35 am
by Genete
What about disable antialising at the render time?
Posted: Sun Dec 05, 2010 8:44 am
That doesn't change the line width, nor does it cure inconsistencies in line width.
