Bind layer AND bind points at the same time?
Posted: Wed Mar 02, 2011 4:54 pm
by VĂ­ctor Paredes
I have the idea I read about a tricky way to get this years ago, but can't find the thread, so I write it again.
Know anybody if is possible to bind a layer to a bone and some points of that same layer to other bone?
I'm having problems with a little experiment.
Thank you very much.
Posted: Wed Mar 02, 2011 6:39 pm
by funksmaname
why don't you select all points and bind to a bone, then select the points you want to rig to bone2 and bind them? Sometimes we overcomplicate things and don't see the wood for the trees :) (or i misunderstood the question ;))
Posted: Thu Mar 03, 2011 4:49 am
by Uolter
You could try with a 2nd bone layer. Put your layer inside and bind the bone. Then add a bone to this 2nd bone layer and bind the points. Maybe with a bit of work around you could do the trick you're looking for...
