Strange effect on my tail
Posted: Fri Jul 15, 2005 7:09 pm
by Mendi
Maybe it's due to the shape effect of the tail, but I guess it's just a bug isn't it?
Posted: Sat Jul 16, 2005 2:02 am
by Rai López
Not a bug, in some cases can occurs... my advice is that you could check that shapes that you belive creates the strange form, you can select the shapes one by one until you can see the scuared texture in the form, delete it and create again after that you check all points are perfectly joined and all is correct...
Posted: Sat Jul 16, 2005 2:19 am
by Mendi
Thank you Ramón, I'll try to reshape it in a different way, but anyway I think this is a bug because the color of the shape is correctly applied and shown.
Posted: Mon Jul 18, 2005 9:43 am
by Lost Marble
I can't say for sure without seeing the Moho file, but my guess is that when you created the fill shape, you included the middle line segments instead of just the outline of the overall shape. It's very important to include just the outside border curves of a shape - if you include any interior curve segments it can make the shape ambiguous. It may look right at first, but as you move it around, color may "spill" out of it as we see here.
Posted: Thu Jul 21, 2005 11:56 am
by Mendi
Thank you all. The problem was solved by removing the inbetween lines and then reapplying the shape fill to the entire tail, and then redrawing again the inbetween lines.
Thanks again.
