Edge Artifcating - no fix?!
Posted: Fri Dec 23, 2011 12:17 pm
by d-soldier
Preview window on left, render output on right... If the layer color is the same as the lower layer color, what are these edges all about? And why hasn't this been fixed in the new version? If anyone found a way around this and I missed it in the forum, please help me out here...
Posted: Fri Dec 23, 2011 1:19 pm
by SvenFoster
as a workaround... if you are only using images you can turn off antialias
I think its something to do with the antialias that has already applied..
(only works on the Export window not render and save.)
viewtopic.php?p=116361#116361
Posted: Fri Dec 23, 2011 1:33 pm
by jonbo
Check this thread, seems to be a similar problem.
viewtopic.php?t=19540&start=0&postdays= ... highlight=
Re: Edge Artifcating - no fix?!
Posted: Wed Sep 12, 2012 12:06 pm
by funksmaname
If you're using patch layers, I've found that swapping the order of what is on top and below can fix these issues... worth a try!
