importing photoshop files
Posted: Mon Dec 26, 2011 5:48 am
by kfried27
Hello,
I am working in AS8.1- I have tried many times to import psd files into AS and no matter how simple the image, it imports as a gray rhomboid shape. I am saving the files in eps format and then using the import function in AS- what am I doing wrong?? Any help is appreciated....
Posted: Mon Dec 26, 2011 9:54 am
Wrong file format. Save it as PNG (allows alpha channel) or JPG.
Posted: Mon Dec 26, 2011 10:00 am
by jonbo
AS can work with eps files, just not very well. Like slowtiger said, maybe try a different format. If you want a vector format, maybe try svg. AS8.1 does a decent job with that format.
Posted: Mon Dec 26, 2011 10:44 am
by Víctor Paredes
Probably I'm not understanding, but have you tried to save your file as .psd (and not as eps) and import it to AS?
Posted: Mon Dec 26, 2011 10:49 am
jonbo: Photoshop creates EPS files very different from Illustrator. The only part of EPS AS can understand is vector information. The only vector information which gets stored in a Photoshop EPS is a clipping path. AS will ignore all bitmap information in an EPS.
Posted: Mon Dec 26, 2011 10:57 am
by jonbo
Ahhh, thanks for the info Slowtiger. :)
Posted: Mon Dec 26, 2011 12:06 pm
by kfried27
Thanks, I will give the png a try
Posted: Mon Dec 26, 2011 12:10 pm
by Víctor Paredes
kfried27 wrote:Thanks, I will give the png a try
I don't use photoshop, but try transforming the vector stuff into raster layers, then save it as psd and import it on AS.
That should work. Exporting to png is fine, but directly import layered psd files save you a lot of work.
Re: importing photoshop files
Posted: Thu Dec 29, 2011 4:50 am
by MustJee
kfried27 wrote:Hello,
Hi, did you try this: File/Import/IMAGE
than pick your *.psd and AS8 asks you: INDIVIDUALLY or COMPOSITE?
1st creats differnt layers (depending on your psd), 2nd the complete pic on one layer.
Hope it helps.
MustJee
