Error upon re-export.
CoffeeStained
I've noticed that if I export something (and the movie file created works), and then re-export for whatever reason, replacing the original, that the new movie file created will not be usable. Mac, Mountain Lion. Anyone else have this problem?
Re: Error upon re-export.
Yes I have had that problem as well, for me the problem goes away if I delete the first .mov file first and the re-export.
I don't know why it behaves so strange.
CoffeeStained
Alternatively, you can simply add a numerical suffix to the filename to creat a new version, and the export will work properly. Only if you replace a file will it fail.
Having the same problem with ASP9--- but not with ASP8.2
Running Snow Leopard ASP9- 32-bit mode.
FIles produced are .mov--- but QT say they are not valid .mov files. --- This happens, whether it's overwriting a previous version-- or a completely new version (with new file name.)
It's hit or miss--- very frustrating after a long 20-minute render...
Also haveing lots of ASP9 crashes, especially if simply renaming a vector layer.
I don't have that problem. It simple overwrites the old file.
Lion 10.7.4
ASP 9 64 bits
Lion 10.7.4
ASP 9 64 bits
Hi GeneteGenete wrote:I don't have that problem. It simple overwrites the old file.
Lion 10.7.4
ASP 9 64 bits
So you're using mac now?
Yes! and you know what does it mean!ulrik wrote:Hi GeneteGenete wrote:I don't have that problem. It simple overwrites the old file.
Lion 10.7.4
ASP 9 64 bits
PS: Still using Linux in a VirtualBox machine inside the iMac.
Oh yes, I can imagineGenete wrote:Yes! and you know what does it mean!ulrik wrote:Hi GeneteGenete wrote:I don't have that problem. It simple overwrites the old file.
Lion 10.7.4
ASP 9 64 bits
