Frame by Frame and new layer layout.
dueyftw
Post by dueyftw »
Here is an idea for some changes. The idea is that the switch layer has two modes. Normal and FBF.
The adding or subtraction of frame numbers should be just clicking under the last frame number. Once for continuing last layer, twice for a new layer.
Dale
dueyftw
Re: Frame by Frame and new layer layout.
Post by dueyftw »
I think that after 4 or 6 frames the next box would have a jump to the frame just before the next layer. So insted of say one hundred boxes with numbers it would go like this:
layer hair_1
_2
_3
_4
_99
layer new hair_100
So from hair_1 to new hair_100 is 99 frames.
Dale
I would seriously doubt that the current architecture of AS could handle this, as each layer adds to file size, and thus performance degradation.
dueyftw
Post by dueyftw »
The layers with out names are nulls, not layers at all, just place holders. Clicking on them would do nothing except to add more or delete them.
Dale
But you still have vector keyframe (key pose) layers, which would suffer the same serious performance hit that switch layer FBF attempts currently do. Your null layers are just a different depiction of the frames between switch keyframes. It is the key pose layers that are the issue.
But no harm in throwing idea out there. Perhaps AS performance will eventually rise to meet this need.
dueyftw
Post by dueyftw »
Why? I have setups with 100, 200 or sometimes 300 layers.
Experiment: duplicate the opening project layers. About 30 layers five times. Place them into a group. (120) layers Copy the group five times. Place them in to a new group. (600) here is where the program locks up on my computer, just stops responding.
So 600 layers is the max? But I'm talking about pointers not layers. So 500 layers and 2000 pointers or null layers would start to strain the system. Of course picture layers would lower these numbers.
Dale
Performance is also very dependent on things like how many points are on each layer. An empty layer doesn't have near the impact a heavy artwork layer does.
dueyftw
Post by dueyftw »
Dale
dueyftw
Post by dueyftw »
