Page 1 of 2
audio problems
Posted: Mon Jan 21, 2013 12:15 am
by Maxwell
Hello
so i have this weird problem in AS9, when i try to import a audio file it tells me that it does not support mp3 files but when i convert the audio file to anything else it does not find it at all. on my home computer it works fine but on my laptop there is this problem. but since i work on my laptop at school i have to fix this or else i go a week without doing a single thing
do i need some special codec or something?
please let me know
Re: audio problems
Posted: Mon Jan 21, 2013 8:49 am
by jessica951
I tried to import an audio file as well (wav and mp3) and it did not work. Strangely it worked when I put it on my desktop. I guess location matters. Try various ones.
Re: audio problems
Posted: Mon Jan 21, 2013 11:38 am
by Maxwell
jessica951 wrote:I tried to import an audio file as well (wav and mp3) and it did not work. Strangely it worked when I put it on my desktop. I guess location matters. Try various ones.
there must be a way... laptops are just as powerful as desktops these days so there would be no reason for it not to work... i'm gonna try re-installing the program and see how that goes
Re: audio problems
Posted: Mon Jan 21, 2013 12:16 pm
by Maxwell
i find an interesting fact... i reuploadet the program and it installed 2 versions of it a (x86) version and a normal version (i have no idea why) aaaand in the 86 version the audio works fine... but in the normal version it does not... BUT if i create something in the normal version and then open it with 86 it still works fine... but if i create something in 86 version with audio and then open it with the normal one... it's broken... i don't know... this should not be happening but now it at least works
Re: audio problems
Posted: Mon Jan 21, 2013 2:16 pm
by jessica951
Maxwell wrote:i find an interesting fact... i reuploadet the program and it installed 2 versions of it a (x86) version and a normal version (i have no idea why) aaaand in the 86 version the audio works fine... but in the normal version it does not... BUT if i create something in the normal version and then open it with 86 it still works fine... but if i create something in 86 version with audio and then open it with the normal one... it's broken... i don't know... this should not be happening but now it at least works
What do you mean broken?
Re: audio problems
by jessica951
Also what version are you using?
Re: audio problems
Posted: Tue Jan 22, 2013 2:15 am
by Maxwell
jessica951 wrote:Also what version are you using?
i am using anime studio pro 9
Re: audio problems
Posted: Tue Jan 22, 2013 8:32 pm
by jessica951
Maxwell wrote:jessica951 wrote:Also what version are you using?
That's interesting. I updated it too and it tried ot install two versions for me too. I canceled the normal version so i just have x86 now. I hope i won't have any audio problems. To me it doesn't really matter because i find it better to add audio in a video editing software
Re: audio problems
Posted: Wed Jan 23, 2013 11:50 pm
by Maxwell
jessica951 wrote:Maxwell wrote:jessica951 wrote:Also what version are you using?
how do you lip sinc then? it is better to add it in the program so you can see how the wave goes
Re: audio problems
Posted: Thu Jan 24, 2013 3:15 am
by Imago
I have got a different issue with audio in ASP 9.2
I use 16bit uncompressed WAV files on my projects, but when I export a movie, it is converted to 32 bit format (IEEE or something like that) and I can't normaliza it in Sony vegas Pro.
Why this happen? In ASP 9.1 it worked fine!
*EDIT*
I found right now that ASP 9.2 also adds a "click" at the start of the audio file.
Please fix it!
Re: audio problems
Posted: Thu Jan 24, 2013 7:06 pm
by jessica951
lip sync with papagayo or not at all. Have you used that before?
Re: audio problems
Posted: Thu Jan 24, 2013 7:07 pm
by jessica951
Imago wrote:I have got a different issue with audio in ASP 9.2
*EDIT*
Please fix it!
I would advise you to import sound in sony vegas instead of AS.
Re: audio problems
Posted: Thu Jan 24, 2013 11:51 pm
by Maxwell
jessica951 wrote:lip sync with papagayo or not at all. Have you used that before?
i use smart bones for the mouth movement...
Re: audio problems
Posted: Fri Jan 25, 2013 3:28 am
by Imago
jessica951 wrote:I would advise you to import sound in sony vegas instead of AS.
Why I have to do two times the same thing?
I paid ASP 9.2 and I expect it works properly!
Re: audio problems
Posted: Fri Jan 25, 2013 6:58 pm
by jessica951
Imago wrote:jessica951 wrote:I would advise you to import sound in sony vegas instead of AS.
well i'm not responsible for the bugs
