Change from 3/4 view to front view
I'm trying to have a character change from a 3/4 view to front view smoothly. Do I use a switch layer if so when I put them in and use the transform layer tool to resize one it changes the other one also. Thanks for any help Gerry.
Re: Change from 3/4 view to front view
I figured it out I was adding key frames when I didn't realize it and once I removed them the switch layer worked
Lostmymarbles
Turns are incredible difficult. A blend morph smart bone may be best.
However , if you are using switch layers it may look choppy. I can tell you that Daffy Duck has three go betweens from front to 3/4 view. This is very important - and explains why we often look a little out of sorts when we try something similar.
Everybody shoot me ....
