HSV modifier images
Posted: Tue Aug 06, 2013 3:52 pm
by Explodey
I'm in the process of reading through the ASD8 User's Manual, and I'm trying to understand what it says about HSV modifier images. On page 215 it says "The best way to try it out is to use one of the HSV modifier images included with Anime Studio." Well, I looked through all the folders in the ASD folder, and I couldn't find anything that says HSV modifier images. Where do I find these modifier images? Is it possible that they didn't get installed because I didn't select the right checkbox during the installation process?
I am using Anime Studio Debut 8 on a Mac, OS X 10.6. Thanks for your help.
Re: HSV modifier images
Posted: Wed Aug 07, 2013 1:44 am
You should first check if this option is available in Debut - create a new layer, open Layer tab, and check "Use HSV modifier image" (if it's not there, you don't have it). This will open a file requester, and you can use any image file. You can easily create your own images for that purposes, as the manual says they should be close to 50% grey.
Example: apply something like this:
http://ftextures.com/textures/tile-bump-map.jpg to a shape with full colour. The result will only show up in Render! (and it's amazing)
Posted: Wed Aug 07, 2013 4:10 pm
by funksmaname
what's a HSV modifier image?
Posted: Wed Aug 07, 2013 4:18 pm
It is an image which controls the Hue Saturation Value(brightness) of a layer it is applied to. Think of it as a texture which changes colours drastically. A value of neutral 50% grey means "no change", anything else means "change". I've never tried this before, looks like it can replace my way of image/mask/blend mode in some cases.
Posted: Wed Aug 07, 2013 4:48 pm
by funksmaname
sounds interesting... please post results!
Posted: Wed Aug 07, 2013 9:42 pm
by Explodey
Thanks for your help everyone. My version of ASD definitely has the option to use HSV images. I'm just wondering why the user's manual would say that it comes with these images, when in fact, it doesn't. Makes me wonder if anything else in the manual is wrong.
Posted: Thu Aug 08, 2013 1:29 am
You're the first one to even ask about this in all the years I've been on this forum.
Posted: Thu Aug 08, 2013 2:59 am
by hayasidist
Posted: Thu Aug 08, 2013 5:23 am
by Lukas
Animators Forum wrote:There Was A Problem
You must be logged in to enter this forum
Remind me why we need 2 fora...
There's links from one forum to the other all the time, such bullshit, the community isn't big enough for that. We just end up with a weaker community and more lost information.
Posted: Thu Aug 08, 2013 2:48 pm
by hayasidist
Hi Lukas. this is what the other forum says about why it's needed:
http://www.kelleytown.com/forum/animato ... OPIC_ID=42 ... and aren't you already registered over there, so all you have to do is log in?
Posted: Fri Aug 09, 2013 1:49 am
by Lukas
Yeah, I can login. But registering there was actually a hassle. Besides, the justifications given for splitting the community up sounds like a bunch of nonsense to me.
The threads you linked are just talk about HSV modifier images, nothing so controversial it couldn't be discussed here.
I've always noticed the developers on this forum are very open to critique and user feedback.
Posted: Fri Aug 09, 2013 3:53 am
Do I have time to spend on even more forums? No.
