Can Transparency be animated
patricia3d
Post by patricia3d »
With ASP Can Transparency be animated ( Png Layer )
I am facing a little problem, and I want to animate the transparency.
Is it possible?
This way At Frame 1 Transparency 0%
at Frame 25 Transparency= 50 %
and so on
Re: Can Transparency be animated
You must check "Allow animated layer effects" in the proprieties of the layer you want to animate (and most of this changes are showed only in the rendered animation)
