ASP 11 - Bone Jumps Position/Rotation w/"Create Smart Bone D
jayfaker
Post by jayfaker »
When I make a bone with a parent into a smart bone using the "Make Smart Bone Dial" menu command, after setting up the parameters in the palette, the blue actions timeline shows up. If I scrub the playhead on the timeline, the bone suddenly jumps to a new position and the whole thing (constraints and all) rotates 90 degrees.
I can then correct the position and orientation of the bone, but it's kind of a pain to have to do that every time.
Mac Pro 2008, Yosemite 10.10.2, ASP 11.0
Bax
Re: ASP 11 - Bone Jumps Position/Rotation w/"Create Smart Bo
Post by Bax »
I could reproduce that bug and it correlates with my bug: viewtopic.php?f=2&t=27561.
But for you I have found a
workaround solution:
Before you scrub the playhead (move away from frame 0) or do anything else in that action, click on the end keyframe and move it. Just one frame and back is okay. then move playhead and you will see, no strange movement of the bone. If you just click on the end keyframe, without moving it, the bone will jump.
Greetings, Bax.
