Disable Space Bar Welding After Frame 0
Posted: Mon Jul 13, 2015 12:00 pm
This occasionally sneaks up on me.
Using Space Bar to play/stop the cursor in the timeline is handy. Using Space Bar to weld point is also handy...
But when you're working down the timeline and you hit Space, thinking that it will Play, but it welds a couple of points together, and it doesn't make that welding sound, and you don't catch it right away, and the cursor doesn't play, and then you hit the space bar a few more times before you finally hit the play button with the mouse, and then you do like another 15 minutes of animation before you realize that you welded two points together 50 steps back, and you have to scrap a bunch of work... It kind of sucks.
Maybe either weld or play should be a combo short cut .... Control + Space, or Alt+Space
