Artwork stays relative to new project space
Posted: Fri Aug 14, 2015 5:24 pm
by ernpchan
When I change my project settings, go from 720 to 1080, my rig's scale stays relative to the new dimensions. Is there a way to disable or counteract this? For example, if I bring a 720 image into a 720 comp in AE and then change that comp to 1080, I would expect to see empty space around my image since that 720 image is smaller than the new 1080 canvas space. I wouldn't expect AE to auto-fit my 720 image to fill 1080. The scale of my group looks to stay at 1 at either 720 or 1080 so I'm not seeing what the compensation scale is in ASP to counteract this. The problem that I'm running into is that I made a rig, then changed the project settings and continued to import artwork. But my newly imported artwork no longer registers with the rig. The workaround is to change back to 720 and continue to rig.
Re: Artwork stays relative to new project space
Posted: Fri Aug 14, 2015 6:15 pm
First, AS is not AE... do not expect them to work the same way.
Second, read the user manual...scale compensation has nothing to do with imported images or project dimensions.
Third, what do you mean by "no longer registers with the rig"? I have changed project dimensions during construction and have never had anything like that happen. Maybe an example file is in order?
Posted: Sat Aug 15, 2015 12:12 am
Bitmaps are treated as 72 dpi and scaled according to the dimension settings at import. An image of 720 px height will fill the project space at 720p exactly. If project dimensions are set to 1080p at import, it will appear smaller.
Once any bitmap is imported it will retain its relative size to the project window even when project dimensions are changed. If you changed dimensions but need to import bitmaps later wich should match what you imported first, changing the project back to your original dimensions is your only way. Fortunately nothing gets lost in that way.
Posted: Sat Aug 15, 2015 12:22 am
by ernpchan
Hi synthsin75,
I made these test images to show what I'm encountering. The cross is the same size as the circle.
Here are the steps to replicate what I'm encountering.
- Start a new scene that's 1280x720.
- Import the Circle image.
- Change your project settings to be 1920x1080.
- Now import the Cross image.
The cross is actually smaller than the circle now. My guess is that since ASP's roots are in vector animation, changing the project size results in your assets changing size to stay proportional to your new camera space and any additions after this change come in at their 1:1 scale.
I guess the proper workflow would be to do all your character rigging in a project and never change the project size dimensions. And then reference that into a new scene with whatever size dimensions that you need for the job.
Thanks.
Posted: Sat Aug 15, 2015 12:03 pm
Slowtiger answered that above. Just revert the project to the original dimensions, import new asset, and change the dimensions back.
Posted: Sat Aug 15, 2015 1:03 pm
by ernpchan
Thanks for the answers. This is very helpful.
