Add bones while seeing points of vector layers
Posted: Thu Oct 08, 2015 5:49 pm
by ernpchan
Is it possible to add bones while seeing the points of my vector layers? It would be helpful to see the vector points so I know where to draw my bones.
Re: Add bones while seeing points of vector layers
Posted: Thu Oct 08, 2015 6:12 pm
by dkwroot
To the right of your layer name you should see a small triangle facing downward, click on the triangle. A menu should pop up, you should see a checkbox for "Paths" click it on and then press the apply button.
Posted: Thu Oct 08, 2015 9:27 pm
by ernpchan
Thanks!
Posted: Thu Oct 08, 2015 10:31 pm
What the..? I did not know you could do that. :shock:
That's going to be useful. Thanks for the tip.
G.
Posted: Fri Oct 09, 2015 12:40 am
by ITAK
dkwroot wrote:To the right of your layer name you should see a small triangle facing downward, click on the triangle. A menu should pop up, you should see a checkbox for "Paths" click it on and then press the apply button.
... or just "Display Quality" (bottom right corner of main window) -> "Wireframe"
