Del key not deleting points
Posted: Wed Jul 13, 2016 3:31 am
by mystd
http://imgur.com/s3CObhN
I've selected that point and I press the delete key and it won't get deleted.
Re: Del key not deleting points
Posted: Wed Jul 13, 2016 3:41 am
by mystd
I've moved the lines around a bit and this is what AS created when I drew a simple circle:
http://imgur.com/e9zmgnG
Posted: Wed Jul 13, 2016 3:54 am
by mystd
Aaaannd Layers are disabled again and only way to fix it is to copy the content to a new file:
http://imgur.com/rjvapyV
Posted: Wed Jul 13, 2016 8:30 am
Do you have the select points tool selected when trying to delete points?
Are you on frame zero when trying to delete points or create layers?
Do you have drawing tools enabled for only frame zero?
Posted: Wed Jul 13, 2016 10:33 am
by mystd
Ahhh ok thank you! So I can only draw when on frame 0 no wonder it didn't work. The option drawing tools enabled for only frame zero should be off this is really confusing for beginners. I'd rather mess up the frames and learn that drawing on different frames than 0 won't change my original than thinking it's a bug because I don't know there is an option to change that.
