"New brush" bug?
Posted: Thu Mar 02, 2017 11:33 pm
by jahnocli
I think I've discovered a bug, but I'd like to air it here before I submit a report to Smith Micro. As part of some work that I'm doing at present, I thought I'd design a brush on the fly to solve a little problem. I left the program open, designed the brush in another program, and then copied that brush to the Brushes folder.
Back in Moho, I looked for the brush, but of course it wasn't there, so I closed Moho down and re-opened it. The new brush was now available, so I tried it out. Worked fine. But now, whenever I try to save that file, I get a "The document wasn't saved properly" warning no matter what I do. Luckily I'm a little OCD when it comes to saving files, so I have previous versions that are OK, but this behaviour can't be normal. Anybody else can replicate this, or had similar problems? I'm using Windows 8, Moho 12.
Re: "New brush" bug?
Posted: Sun Mar 05, 2017 2:02 am
by chucky
Yes I have seen this, I can't offer any wisdom yet though , just to say it has never stopped me actually saving the file in the long run, maybe I change the name or something or press the reload tools shortcut ( which I have as a macro on my smartphone- couldn't tell you the keys off the top of my head)
Posted: Sun Mar 05, 2017 11:10 am
It's Shift-Ctrl-Alt-L, isn't it? I think that reloads scripts in general.
Posted: Wed Aug 16, 2017 9:45 am
by hayasidist
Recently I've just been hitting this "not saved properly" issue more often than is pleasant. I'm really not sure what exactly is causing the problem - I'm working back and forth between IE, PS and Moho with a lot of image cut/paste etc
what I did as a work-round was rename the file on disk and then save...
but I found this:
http://lostmarble.com/forum/viewtopic.p ... 4&p=154543 and the next time I did as suggested and killed off the COM Surrogate tasks.. all worked fine after that.
@john -- so it's still happening - did you submit a bug report??? (if not, I will...)
Posted: Wed Aug 16, 2017 11:53 am
by jahnocli
hayasidist wrote:Recently I've just been hitting this "not saved properly" issue more often than is pleasant. I'm really not sure what exactly is causing the problem - I'm working back and forth between IE, PS and Moho with a lot of image cut/paste etc
but I found this:
No, I didn't submit a bug report -- I'm quite wary about that, because stuff like this is usually user error for me! Luckily, (touch wood!) it has only happened that one time. It is odd though, isn't it?
