Visible Bones in Render?
Posted: Sun Apr 02, 2017 8:28 pm
by Little Yamori
Is there a way to have bones visible in a render?
Re: Visible Bones in Render?
Posted: Mon Apr 03, 2017 1:33 am
by jahnocli
First thing I'd do is change Display Quality to "Wireframe" (bottom right of screen area), and do a screen capture...of course, if you wanted to capture a sequence, this could get tedious very quickly!
Posted: Mon Apr 03, 2017 5:34 am
by VĂ­ctor Paredes
With Ctrl+Shift+R you can record a video from the workspace. Since it's a screen recording feature, paths, bones and any element currently visible will appear in the video.
The video quality is poor though, because this feature was created to quickly check the real timing of heavy animation.
In my case, the video is temporarily saved here:
\Users\VP\Mohos\MohoContent\Moho Pro\Render Cache\
Posted: Mon Apr 03, 2017 10:44 am
by Little Yamori
Thank you both,
I guess I jumped the gun a little as I was looking at the Bvh 3d bone animation that was just posted in Share Your Work, I realize after I posted here that that was the effect of the script, but I managed to mimic it by simply drawing a bone shape, copying it for each bone and binding it to the bone it represents to get the same look.
Thanks again.
P.S. I guess the real motivation for attempting to copy the Bvh character rig, was that if a script can motion capture and then generate a rig that moves perfectly to human movement, then why can't one be constructed by hand. So I created a bone layout as per the sample video, and was ok with the results since it only took about 20 minutes. it was after the render that I went "Whoops!" "Can't see the bones!" But it's now done. But to get back to the important stuff, if we can create a rig that moves perfectly like said example, then the rest is what we bind to it, and off we go.....
