Hey guys How can I fix this problem :
the arm is transparent when touch the body.
http://imgur.com/a/0qvOm
How can i this problem
Re: How can i this problem
You can put the arm in a different shape, (on the same layer or on a different layer), to prevent this from happening. This is the normal behavior when a shape intersects itself.
thank you very much, I fixedlwaxana wrote:You can put the arm in a different shape, (on the same layer or on a different layer), to prevent this from happening. This is the normal behavior when a shape intersects itself.
