playback speed doubled
Posted: Mon Dec 18, 2017 5:48 am
by jazz
Hello,
I am working in moho 12.4 and in one project the playback speed has doubled(its playing way to fast). In a other project it seams ok.
I count the seconds and its of, its playing too fast.
Its not that I have scaled the keyframes.
I have not changed the framerate in the projectsettings,they are ok.
Any ideas/tips?
cheers
Re: playback speed doubled
Posted: Mon Dec 18, 2017 6:00 am
by jazz
I use physic in the project and if I remove this layer, it is ok again.
strange.....
Posted: Sat Feb 24, 2018 4:30 pm
by BarryMcMahon
I have the same thing. What does that mean. Don't use physics?
Posted: Sun Feb 25, 2018 4:14 am
by drumlug13
I've had that happen before. Seems like a lot of weird glitches like that can self correct when you relaunch Moho.
Another thing that can affect the playback speed is "Allow Frame Skipping". It's under your Animation options in the top menu bar. Toggle it off/on see if it makes a difference.
You could also try a test render to see if the timing has changed at export as well.
