Mouth Switch Error
Posted: Fri Feb 15, 2019 5:08 pm
by Leon13DM
I am trying to make an animation that uses a voice clip I made. I used a voice changer to give my voice a more cartoonish effect, but this seems to have had an effect Moho's Voice Recognition ability, as when I assigned the Mouth Layers to switch to the voice, it only does so after every 30 frames. Is there a way to modify the voice recognition settings to fix this? Heck, I'd even take an option that randomly switches the mouth layers. I just don't want to input the switch frames individually myself.
Re: Mouth Switch Error
Posted: Sat Feb 16, 2019 1:04 am
by hayasidist
I assume you're doing the final render from Moho? If so, how about you have two audio files -- one the voice you want to hear and one to control the mouth - set the mouth switch to use the "control" track but set its "visibility" to off (use the "eyes" icon).
(If you're using a video editor it's a different approach)
Posted: Sat Feb 16, 2019 1:26 am
by Shizukuishi
It seems the sound wave is a little flat. You could try to amplify it on an audio editor (e.g. Audacity) to gain higher peaks.
Posted: Sat Feb 16, 2019 11:29 am
by Leon13DM
I attempted to raise the audio in Moho using the Audio File's option menu, but the switch remains the same, even when the waves are increased. I tried the first method as well and it didn't work.
Posted: Sat Feb 16, 2019 12:12 pm
Leon13DM wrote:I attempted to raise the audio in Moho using the Audio File's option menu, but the switch remains the same, even when the waves are increased. I tried the first method as well and it didn't work.
Raising the volume in Moho doesn't change the audio's amplitude. You'd need to do that in an audio editor, like Audacity.
Posted: Sat Feb 16, 2019 2:01 pm
by Leon13DM
I tried Audacity and it works now.
