tool for align .
Posted: Wed Apr 24, 2019 11:34 pm
by Deepurana749
is there any tool in moho to arrange the point shape or to align them properly like path finder in illustrator
Re: tool for align .
Posted: Thu Apr 25, 2019 12:31 am
Other than the grid, no.
Posted: Thu Apr 25, 2019 4:10 am
by Deepurana749
slowtiger wrote:Other than the grid, no.
is there any method for custom your own brushes
Posted: Thu Apr 25, 2019 5:24 am
by hayasidist
Deepurana749 wrote:is there any method for custom your own brushes
do you mean making your own custom brushes? - If so, yes -- take a look at:
viewtopic.php?f=13&t=32558&p=185907
Posted: Thu Apr 25, 2019 7:58 am
Unfortunately, no.
As a workaround. I usually make guide lines (using Add Points) or grids (using the Grid tool) in their own layers so I can scale and position them over or under the art points/shapes/layers I'm aligning. Unfortunately, no snapping but it works well enough most of the time.
Tip: If you enable Paths in the layer's Quick Settings, the guides are visible even where they're not stroked and not selected.
For guides I use a lot, I keep a folder for them so I don't have to keep re-creating them, and I can import them into any project.
As mentioned above, there is an editable Grid that has snapping. It's fine for quickly aligning elements at regular intervals but it's also awkward to edit. And because every layer has its own local grid settings, it's use is somewhat limited between multiple layers. I use like to use it to align my SBDs but not for much else.
