HELP! objects out of place when moved from camera view
Posted: Sat Jul 20, 2019 8:30 am
by j316
so i created multiple vector images with moho12 and put them in folder groups that are also put in a main folder
when i pull the main folder with all images out of the camera view, some of the images slide out of place
this happens also to imported images like png files.
i dont want this to happen. how can i stop this
Re: HELP! objects out of place when moved from camera view
Posted: Sat Jul 20, 2019 10:03 am
by hayasidist
take a look at the layer z for the layers that "slide" - chances are that they're at a different z from the ones that "work".
then take a look at edit / preferences / layers-objects / auto center new layers -- and make sure it's unchecked!
if that isn't it - please say!
Posted: Sat Jul 20, 2019 11:37 am
by j316
thank you, it work. i had to go through about 200 layers to check if the Z position was set to zero, about 30% weren't.
thanks again
Posted: Tue Aug 20, 2019 7:40 am
by SuperSGL
You could have also selected the orbit camera and rotated in the scene to see which layers are on a different ' z ' I believe you can select layers in this perspective as well.
